Проблемы с настройкой VNC-сессии для RHEL 7 на Power8
Я следую за http://www.linuxexplorers.com/2014/04/configure-vnc-server-in-red-hat-enterprise-linux-7-rhel7/ для настройки VNC-сервера RHEL 7.
На последнем этапе настройки "systemctl start vncserver@:1.service" я получил
Job for vncserver@:1.service failed. See 'systemctl status vncserver@:1.service' and 'journalctl -xn' for details.
journalctl -xn
-- Logs begin at Tue 2014-09-02 14:17:21 CDT, end at Tue 2014-09-02 15:28:53 CDT. --
Sep 02 15:28:53 xx.xx.xx.com systemd[1]: Started Session c2 of user zzz.
-- Subject: Unit session-c2.scope has finished start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit session-c2.scope has finished starting up.
-- The start-up result is done.
Sep 02 15:28:53 xx.xx.xx.com runuser[42609]: pam_unix(runuser-l:session): session opened for user yyy
Sep 02 15:28:53 xx.xx.xx.com runuser[42609]: Warning: xx.xx.xx.com:1 is taken because of /tmp
Sep 02 15:28:53 xx.xx.xx.com runuser[42609]: Remove this file if there is no X server xx.xx.xx.com
Sep 02 15:28:53 xx.xx.xx.com runuser[42609]: A VNC server is already running as :1
Sep 02 15:28:53 xx.xx.xx.com runuser[42609]: pam_unix(runuser-l:session): session closed for user yyy
Sep 02 15:28:53 xx.xx.xx.com systemd[1]: vncserver@:1.service: control process exited, code=exited s
Sep 02 15:28:53 xx.xx.xx.com systemd[1]: Failed to start Remote desktop service (VNC).
-- Subject: Unit vncserver@:1.service has failed
-- Unit vncserver@:1.service has failed.
-- The result is failed.
Sep 02 15:28:53 xx.xx.xx.com systemd[1]: Unit vncserver@:1.service entered failed state.
Sep 02 15:28:53 xx.xx.xx.com systemd[1]: Failed to mark scope session-c2.scope as abandoned : Stale
По некоторым причинам, похоже, что экземпляр vncserver уже запущен. Теперь, почему вы не можете подключиться, возможно, это другой вопрос / проблема
Сообщения об ошибках направляют вас на удаление файлов блокировки / tmp. Удалите эти сообщения в соответствии с рекомендациями и повторите попытку.
От коллеги..
Либо уже существует экземпляр VNC-сервера, работающий на:1, либо предыдущий: 1 Экземпляр VNC не был правильно отключен. В любом случае, vncserver проверяет и находит временные файлы для сеанса: 1 в /tmp/.X11-unix каталог.
Правильный способ выключения VNC-сервера - использовать vncserver -kill :1, Это следует сделать до перезапуска системы, либо вручную, либо в сценарии завершения работы.
Если VNC-сервер отсутствует: 1 экземпляр уже запущен, очистите /tmp/.X11-unix каталог и попробуйте перезапустить vncserver.
Job for vncserver@:7.service failed. See 'systemctl status vncserver@:7.service' and 'journalctl -xn' for details.
Удалить эту папку:
rm -r /tmp/.X11-unix/
Это работа для меня.
Ссылка:
